Pocket GPS World :: View topic - Checkpoint not seeing overlay files
TerryT
PostPosted: Thu Nov 18, 2004 4:11 pm    Post subject: Checkpoint not seeing overlay files Reply with quote
Hi everyone.
Newbie here Smile
I have a Mitac Mio 168 running Tomtom 3.01, Checkpoint 3.2 using the pocket gps speed camera db. Everything works fine if I switch on the PPC via the power button, and start Checkpoint. If I start the PPC via a hard button shortcut (which turns the PPC on and opens Checkpoint/tomtom) Checkpoint doesn't see the overlay files (nothing under the overlay settings/not sync'd).
Is this a bug? It kinda makes the Checkpoint hard button shortcut useless now Sad
DavidW
PostPosted: Thu Nov 18, 2004 6:09 pm    Post subject: Reply with quote
Do things work if you turn on the Pocket PC, wait a few seconds, then press the hardware button to start up CheckPOInt?
If so (as I suspect they will), the problem is that the memory card in the Pocket PC that contains the overlays isn't powering up quickly enough. This is a known limitation of much if not all Pocket PC hardware.
TerryT
PostPosted: Thu Nov 18, 2004 6:26 pm    Post subject: Reply with quote
Yep, the button shortcut works if the PPC is already switched on. I thought it might've been the SD card as well but Tomtom can see the maps which is also on it Question
DavidW
PostPosted: Thu Nov 18, 2004 6:29 pm    Post subject: Reply with quote
TomTom Navigator takes sufficiently long to start up that I suspect, by then, the memory card is powered up and ready.
The answer is to press the power button, wait a second or two, then press the button to start CheckPOInt. This issue is why certain software (such as Today Screen plugins) has to be in main memory and not on the storage card.
To keep the storage card(s) powered up all the time would be an unacceptable drain on the Pocket PC's battery.
TerryT
PostPosted: Thu Nov 18, 2004 6:31 pm    Post subject: Reply with quote
Thanks.
Do you think it would make any difference if I used PoiPlace to download the poi's instead?
DavidW
PostPosted: Thu Nov 18, 2004 6:36 pm    Post subject: Reply with quote
I very much doubt it - unless POIplace POIs go in main memory. I can't remember and can't easily check. I never much liked CheckPOInt version 3, preferring instead to stick with version 2.0.2, and these days I use GPSAssist anyway.
I think the issue is simply that you're starting a program that tries to access data on your memory card before the memory card hardware is powered up and ready.
TerryT
PostPosted: Thu Nov 18, 2004 6:42 pm    Post subject: Reply with quote
Looks like I'll just have to turn the PPC on first, thanks David Smile
I might give Poiplace a try anyway for the speed rated cameras if anything else.
22.094 (25 Sep 24)
