alanlakes Lifetime Member
Joined: Dec 28, 2005 Posts: 100 Location: Chevington, Suffolk
Posted: Tue Feb 14, 2012 3:52 pm Post subject: |
I had the same problem on my Go 750 (non-Live) and this was the cure from Tomtom which works. It may not be the same for a 520 but after a backup to pc it could be worth a try.
Alan
In order to resolve the issue, please follow the below given steps.
1- Remove the GNS folder from the internal memory of the device.
2- Remove and reinstalled the TomTom application.
The steps for reinstalling TomTom application is as follow.
STEP 1 Backup the device:
- Click ‘Manage my device’ in TomTom HOME and select the ‘Items on device’ tab
- Select ‘Maps’ and ‘Postcodes’
- Click ‘Copy items to computer’
- Close HOME
I would also suggest you to backup your favourites or POIs from the device. To do that, please follow the link http://uk.support.tomtom.com/app/answers/detail/a_id/7028/kw/poi
STEP 2 Reinstall application:
1 - Delete the application from device
- Connect the device to the computer and open TomTom HOME
- Go to Manage My Device
- Click ‘items on my device’
- Select the application and click ‘remove items from device’
2 - Delete the applications from the computer
- Click ‘items on computer’
- Select the applications (there may be more than one)
- Click ‘remove items from computer’
3 - Re-download the application
- Go to Update My Device
- Click on Update and install
- Repeat this process until no more applications are offered.
3- Paste the attached file into the internal memory of the device and replace it in case the if you been told to replace the file.
4-Update de device in TomTom, in case that new updates are available. _________________ Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker. |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Tue Feb 14, 2012 4:08 pm Post subject: |
Before you do all of the above it might be worth simply renaming the /gns/gnsdata file to /gns/gnsdata.old
Then try your tmc receiver again. _________________ Paul |
Andy_P Pocket GPS Moderator
Posted: Wed Feb 15, 2012 7:24 pm Post subject: |
Thanks for the instructions from TomTom, "alanlakes".
Any chance you could post up the file mentioned in step 3?
If you can't host it yourself then maybe send it to one of the admin team and they could put it up. _________________ "Settling in nicely" ;-) |
Posted: Wed Feb 15, 2012 8:48 pm Post subject: |
Sorry no attached file on the original email. The reason, I presume is that this is a standard reply to the problem and in my case no file was required.
I can only repeat that it worked for me.
Alan _________________ Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker. |
Posted: Wed Feb 15, 2012 10:15 pm Post subject: |
The GNS folder and its contents (a single file with the name of TmcEApi.so) is included in a new Navcore download when the software is updated so no extra files would be required over and above the update - Mike |
Posted: Thu Feb 16, 2012 2:02 am Post subject: |
I wasn't thinking it was an EXTRA file... but a replacement. _________________ "Settling in nicely" ;-) |
Rickj2903 Occasional Visitor
Posted: Fri Feb 17, 2012 8:10 pm Post subject: |
I have discovered over the last couple of days that not only can I not get HDT (error 1008) my RDS-TMC system is unable to lock onto a signal and give me Traffic that way. Before the update it worked very well, now nothing.
Is anyone else experiencing this? _________________ Go 940 (deceased) Live 1000. |
