Pocket GPS World :: View topic - Co-ordinates
Co-ordinates
arkiboys
PostPosted: Thu Jul 23, 2009 8:45 pm    Post subject: Co-ordinates Reply with quote
In my navi 250, in the coordinates section, how do I set the following coordinates please?
49.405938, 3.128160
In the sat nav, it has the following boxes to enter data i.e. a box for N, s, w, E
PostPosted: Fri Jul 24, 2009 9:41 am    Post subject: Reply with quote
'decimal degrees' is the format you have posted and is 'north','east'
so you would put:
N: 49.405938
E: 3.128160
for south or west values you would need to put a 'minus sign' eg -1.23456
hope that helps?
arkiboys
PostPosted: Fri Jul 24, 2009 10:25 am    Post subject: Reply with quote
Are you sure about this?
Becasue on my device on the corner of the box has a degree sign and on the last box had a sign similar to '
the default in there are the following figures:
N in the first box, 51 (Degree sign i.e. the little circle) in the middle box and 35.937 in the last box with a little sign as '
Then in the lower set of boxes the figures are:
w in the first box, 0 in the next box with circle and 23.965 in the last box with ' sign
Any thoughts please?
PostPosted: Fri Jul 24, 2009 10:34 am    Post subject: Reply with quote
That sounds like its using degrees decimal minutes rather than decimal degrees for the coordinate format - Mike
arkiboys
PostPosted: Fri Jul 24, 2009 11:24 am    Post subject: Reply with quote
I am still not sure in which boxes exactly to enter these figures though.
PostPosted: Fri Jul 24, 2009 12:40 pm    Post subject: Reply with quote
they will need converting to the correct format first.
49.405938, 3.128160
latitude:
49.405938 = 49 whole degrees + 0.405938 degrees
0.405938 degrees x 60 = 24.35628 minutes
it is positive therefore north so enter: N 49° 24.35628'
longitude:
3.128160 = 3 whole degrees + 0.128160 degrees
0.128160 degrees x 60 = 7.6896 minutes
it is positive therefore east so enter: E 3° 7.6896'
hope that helps
arkiboys
PostPosted: Fri Jul 24, 2009 12:45 pm    Post subject: Reply with quote
yes. done it now.
Thank you.
PostPosted: Fri Jul 24, 2009 1:18 pm    Post subject: Reply with quote
by the way, as you posted in the garmin forum is it actually a nuvi250 as opposed to a navi 250?
if so then there should be a setting to change the format needed for the coordinates - can;t remember where though...!
dales
PostPosted: Fri Jul 24, 2009 3:18 pm    Post subject: Reply with quote
On the nuvi255, it's Where to .. Coordinates .. Format.
arkiboys
PostPosted: Fri Jul 24, 2009 10:30 pm    Post subject: Reply with quote
49.405938, 3.128160
latitude:
longitude:
hope that helps
How do you know if it is south or west?
PostPosted: Sat Jul 25, 2009 12:06 am    Post subject: Reply with quote
If its a negative number it will be South (Lat) or West (Long) - Mike
PostPosted: Sat Jul 25, 2009 1:31 am    Post subject: Reply with quote
e.g.
-42.12345,2.12345
the 1st half (latitude) is negative so is SOUTH, the 2nd is positive so is east.
arkiboys
PostPosted: Sat Jul 25, 2009 6:41 am    Post subject: Reply with quote
I see. thanks
USing the initial coordinates I gave, the sat nav does not seem to be pointing to the right location.
Those coordinates should give a place called "Berny Riviere" in France.
Do you get that please?
PostPosted: Sat Jul 25, 2009 8:29 am    Post subject: Reply with quote
Both of the numbers you gave are positive therefore its North and East, I think you might still have the device set to Degrees, decimal minutes rather than decimal degrees as I get the correct location using Google Earth - Mike
dales
PostPosted: Sat Jul 25, 2009 4:28 pm    Post subject: Reply with quote
Yes, I get Berny-Riviere on my nuvi, using your co-ordinates with the unit's Co-ordinates Format set to decimal degrees (h ddd.ddddd).
Dales.
22.094 (25 Sep 24)
