Pocket GPS World :: View topic - Problem with Pocket Streets and GPS CF cards ?
HungryHaggis
PostPosted: Fri May 21, 2004 7:38 am    Post subject: Problem with Pocket Streets and GPS CF cards ? Reply with quote
I have a “Sysonchip” CF card that I am using with a Jornada 545. The Leadtek software on the Jornada recognises the CF card and I am seeing all the correct signs for NMEA signals (satellites, development screen etc).
The Leadtek s/ware sees the CF card on port 2. When I use this port the Leadtek software works great and all looks good. However when I start PocketStreets [version 11.00(18.0200) so it is a recent version] it shows ports 1,3 and 4…. no port 2 ?
If I first close the Leadtek software before selecting PocketStreets, port 2 is now in the list of available ports but it the CF card doesn’t appear to”start” (ie LED doesn’t come on) so no signal is received by Pocket Streets ?.
I appear to get the same behaviour on a new iPaq2210 that I have if I move the card over to this machine
Any ideas how I use Pocket Streets with a CF card ?
PostPosted: Fri May 21, 2004 3:40 pm    Post subject: Reply with quote
You could try tweaking the registry
HKCU\Software\Microsoft\Pocket Streets\10\GPS_COM_PORT
HungryHaggis
PostPosted: Sun May 23, 2004 9:23 pm    Post subject: Reply with quote
I assume this is a setting on the Jornada ?. I can't find the directory that you state - or even something close ?
PostPosted: Mon May 24, 2004 12:04 am    Post subject: Reply with quote
We are talking about the Registry here, not about directories. You need a registry editor for that.
Fuego
PostPosted: Wed Jun 23, 2004 9:04 pm    Post subject: Reply with quote
As a matter of interest, is this Pocket Streets that comes with Autoroute 2004, or an earlier version?
I know that PS/AR2003 could not use virtual COM ports, such as a bluetooth COM port. I presume the CF card presents a virtual COM port interface too. I took the issue up with MS support and got told, "that's the way it is". Neither could they tell me if the problem would be fixed in AR2004.
Decided that I would not be buying AR2004, despite having been a regular customer of past versions.
PostPosted: Wed Jun 23, 2004 9:52 pm    Post subject: Reply with quote
You need Pocket Streets version 11.00 or better. I guess that's what they add to the AR CDs, but you can also download it separate.
Fuego
PostPosted: Wed Jun 23, 2004 10:21 pm    Post subject: Reply with quote
Any idea where I can download this please?
I looked on microsoft.handango.com and could only see PS2003 (which is the version that I have - v10.00/07.2500), or PS for Smart Phone, which is presumably no good for an iPAQ 3870 with WM2003.
On the MS site they have a PS2003 update, which I applied already, last year, but there does not appear to be anything later, that would suggest a version 11 or better update/download.
TIA
icsys
PostPosted: Thu Jun 24, 2004 1:23 am    Post subject: Reply with quote
Here you go
Sorry, can't get the link to work in short version Confused Sad Crying or Very sad
(Fixed. LB)
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
22.094 (25 Sep 24)
