HungryHaggis Occasional Visitor
Posted: Fri May 21, 2004 7:38 am Post subject: Problem with Pocket Streets and GPS CF cards ? |
I have a “Sysonchip” CF card that I am using with a Jornada 545. The Leadtek software on the Jornada recognises the CF card and I am seeing all the correct signs for NMEA signals (satellites, development screen etc).
The Leadtek s/ware sees the CF card on port 2. When I use this port the Leadtek software works great and all looks good. However when I start PocketStreets [version 11.00(18.0200) so it is a recent version] it shows ports 1,3 and 4…. no port 2 ?
If I first close the Leadtek software before selecting PocketStreets, port 2 is now in the list of available ports but it the CF card doesn’t appear to”start” (ie LED doesn’t come on) so no signal is received by Pocket Streets ?.
I appear to get the same behaviour on a new iPaq2210 that I have if I move the card over to this machine
Any ideas how I use Pocket Streets with a CF card ? |
lbendlin Pocket GPS Staff
Posted: Fri May 21, 2004 3:40 pm Post subject: |
You could try tweaking the registry
HKCU\Software\Microsoft\Pocket Streets\10\GPS_COM_PORT _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun May 23, 2004 9:23 pm Post subject: |
I assume this is a setting on the Jornada ?. I can't find the directory that you state - or even something close ? |
Posted: Mon May 24, 2004 12:04 am Post subject: |
We are talking about the Registry here, not about directories. You need a registry editor for that. _________________ Lutz
Fuego Regular Visitor
Joined: 07/06/2003 16:45:14 Posts: 114 Location: United Kingdom
Posted: Wed Jun 23, 2004 9:04 pm Post subject: |
As a matter of interest, is this Pocket Streets that comes with Autoroute 2004, or an earlier version?
I know that PS/AR2003 could not use virtual COM ports, such as a bluetooth COM port. I presume the CF card presents a virtual COM port interface too. I took the issue up with MS support and got told, "that's the way it is". Neither could they tell me if the problem would be fixed in AR2004.
Decided that I would not be buying AR2004, despite having been a regular customer of past versions. |
Posted: Wed Jun 23, 2004 9:52 pm Post subject: |
You need Pocket Streets version 11.00 or better. I guess that's what they add to the AR CDs, but you can also download it separate. _________________ Lutz
Posted: Wed Jun 23, 2004 10:21 pm Post subject: |
Any idea where I can download this please?
I looked on microsoft.handango.com and could only see PS2003 (which is the version that I have - v10.00/07.2500), or PS for Smart Phone, which is presumably no good for an iPAQ 3870 with WM2003.
On the MS site they have a PS2003 update, which I applied already, last year, but there does not appear to be anything later, that would suggest a version 11 or better update/download.
TIA |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Thu Jun 24, 2004 1:23 am Post subject: |
Here you go
Sorry, can't get the link to work in short version
(Fixed. LB) _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
