Mike777 Regular Visitor
Posted: Sat Feb 21, 2009 7:30 pm Post subject: Routes and waypoints |
Hi all
I am planning a walk in the lakes which involves climbing 3 peaks.
I need to set waypoints and I am fine with that…………what I would also like the active 10 to show is distance to next waypoint and also distance to next peak. I know the active 10 shows distance to next waypoint but can it show the next peak which may be a number of way points away. I though about having the peaks as POI but the display is for nearest POI rather then next which maybe a problem having pass a peak it would look back for sometime
Any ideas or recommendations…
Many thanks for your time
Regards
Mike |
Posted: Sat Feb 21, 2009 7:36 pm Post subject: |
Edit the POI on the device and simply delete each one in turn as you pass the summit, I can't think of any other way to do this. Don't forget the distance will be a straight line rather than your true path so it will display a much shorter distance than the actual one involved while walking - Mike |
LostMike Frequent Visitor
Joined: Jan 17, 2008 Posts: 369 Location: Monmouthshire
Posted: Sat Feb 21, 2009 7:59 pm Post subject: |
Or you could plot a separate route to each peak e.g from one to the next. Then you could see how far you were into the route. Change the route after each peak. _________________ LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525 |
Gibbo10 Frequent Visitor
Joined: Sep 21, 2008 Posts: 262 Location: Swindon, Wilts
Posted: Sat Feb 21, 2009 8:11 pm Post subject: |
Could use the set goto each time you pass a peak set a new goto point at the next peak. |
ocam Occasional Visitor
Posted: Sat Feb 21, 2009 9:46 pm Post subject: Re: Routes and waypoints |
I'd say the easiest way to get an idea (again, only a straight line distance) would be to use the 'range finder' function. Since I discovered this little gem of an idea in the manual I use it all the time.
Just nudge the joystick, then in planning move the locator circle to the next peak. The data box shows the distance from your current location. |
