TheM Frequent Visitor
Posted: Mon May 19, 2008 9:21 pm Post subject: |
memoryweaver wrote: | Anyone got a default settings file from an s90i to compare? Sometimes 'features' can be turned on for lesser devices if you just know the right words for the settings file -- seeing a s90i file would be very useful... |
Wouldn't help you. S90i has larger executable so stuff was cut out from S30, and transferring it to S30 wouldn't help either as Navman's models always had a protection that prevented that sort of thing. Plus S90i has three times as much RAM as S30 so even if you somehow managed to do it, it still wouldn't work. |
movilogo Occasional Visitor
Posted: Mon May 19, 2008 10:06 pm Post subject: |
Is it not anyway possible to add features of S70/S90 etc. to S30?
Will copying the files from a higher model to lower model would work [via SD card]?
Posted: Mon May 19, 2008 10:37 pm Post subject: |
movilogo wrote: | Will copying the files from a higher model to lower model would work [via SD card]? |
No. And even if you managed to copy it, then bypass all copyright checks and get it started, there is still the ultimate copyright protection -- S30 has nowhere near enough memory to run S90i software. |
Posted: Mon May 19, 2008 10:40 pm Post subject: |
movilogo wrote: | Is it not anyway possible to add features of S70/S90 etc. to S30? |
Which higher-end features would you most like to have on S30? |
Posted: Tue May 20, 2008 12:24 pm Post subject: |
S30 doesn't allow lat/long input while entering a destination. |
Posted: Mon May 26, 2008 9:51 pm Post subject: |
movilogo wrote: | S30 doesn't allow lat/long input while entering a destination. |
I don't believe any models in S-Series have this capability. |
MarkS90i Occasional Visitor
Posted: Wed Jul 02, 2008 9:07 am Post subject: Increasing Demo Speed S Series |
What did you guys use to edit the xml files? |
Posted: Wed Jul 02, 2008 9:27 pm Post subject: Re: Increasing Demo Speed S Series |
MarkS90i wrote: | What did you guys use to edit the xml files? |
I used Notepad++ (with XML Tools plugin) -- it's free as in "free speech", but also as in "free beer". |
