neilkeeno Occasional Visitor
Posted: Sat Jul 07, 2007 1:38 pm Post subject: HELP WITH TOM TOM GO |
i lost my map this morning and even when i back up from pc it still not there, i have had to install original one from the disc for time being which i have done, i have my device code, but not product id.
now i installed tomtom home and have seen a picture of where i should be able to see product id but it does not come up?
any ideas how i can activate this basic map from my disc, i dont have the disc case or box with the product code on
help please |
Andy_P Pocket GPS Moderator
Posted: Sat Jul 07, 2007 6:51 pm Post subject: |
Sorry to hear your problems. In your other post you say you added some POIs. Did you wait for the copying to finish before you unplugged the TomTom?
If you were using Windows to do the copying, you should always use the "Safely remove hardware" icon that appears in the system tray (by the clock) before you unplug, as the copying can LOOK like it has finished before it has. Neglecting to do this is a really easy way to corrupt files or the whole card.
If you used Home, the same thing applies. IIRC, you need to click on "My Device" and follow the prompts before you remove the plug.
Now, you don't say what model you have, but as you say there was an original map on a CD, that must be from the original Go "Classic" as no more recent model has supplied the map on CD (in the UK at least).
But from what you say, this is not the map you have been using up to now. How did you buy that one? The new product code would have arrived with it.
If the new map appears on TomTom Home, double clicking on the text, should bring up a box with the Product ID. Hovering the mouse over the text also brings up a "tooltip" with the info.
That code needs to be combined with the "Device code" of your Go at www.ttcode.com to get an "activation code" which is what you need to enter on-screen if and when the Go asks for it.
But, the best thing would be to get your latest map back from the backup.
Have you looked at the backup in Windows Explorer? There should be a folder with the maps name, something like "Great_Britain-Map" or "UK and IE plus major roads of WE" or whatever your map was.
Inside that folder should be a whole bunch of files but the most important ones will be called "cline.dat", "cname.dat,"cnode.dat" and "faces.dat". Can you find those? If so we are in with a chance of getting it back.
Sorry, a bit of a stream of consciousness there, but if you can answer any of the questions raised, and give us as much information about what you've actually done, and what map you were using, it will all help. |
Posted: Sun Jul 08, 2007 11:06 am Post subject: |
Hi thanks for the reply,
It is the classic and i bought it 2nd hand with a map already on it, not the one that it was shipped with, i stupidly chucked away cd case and box. i added the 2 poi via windows and could well have removed before finished and not exited the connection properly. i subsequently downloaded tom tom home to try and find product code of the basic map on disc and could not find it. i have downloaded a new map from tom tom on their advice, they say effectivley as i have no code i have no product. i have the 6.75 map to install later, it has downloaded from the web page to my tom tom home but will not fit on my sc card so a trip to dixons is on in a minute...
can i just check if i put this map on later and put the poi's on and it does it again, as long as i have the product code i can reinstall this map as many times as i like as effectivley i have proof of purchase?
thanks |
Posted: Sun Jul 08, 2007 8:00 pm Post subject: |
Update
i am about to smash my tom tom to bits
after putting 2 poi on it yesterday and it wiping the map, i have just bought a new memory card installed my new map and the tom tom application (8mb)
after putting an application on that allows for 7 digit postcode, i then disconnected tom tom propely by ejecting it, it turns on know map found.
it seems to me whenever anything updates or is put onto it i get the no maps found message come up, and to be honest it is getting on my tits
i only want my new map with a couple of poi and 7 digit postcode search.......
edited by PaulB2005 to remove swearing |
Posted: Sun Jul 08, 2007 8:03 pm Post subject: |
should have added, after installing my new map and the application (8mb) i did a back up and it was all working fine at this point. after it saying no maps found i thought haha i will run the back up. go to restore and i get a error message
same as yesterday, it seems whatever i change on the tomtom leads to no maps found, and when i get this i can't even restore despite it all being in working order at the point of restore.
Posted: Sun Jul 08, 2007 9:32 pm Post subject: |
ok i seem to have my map working with the latest application 6.520 and map GB 675, but the only downside is i have now lost the facility to search by 7 digit postcode and its main use is this. i bought the map via a download yesterday and thought it would have this? |
sgould Frequent Visitor
Posted: Sun Jul 08, 2007 9:52 pm Post subject: |
What map do you have on the GO?
What size card do you have?
How are you looking to select the postcodes? After the software was updated to v6.52 the postcode button was moved to "Address" page. It's not on the front "Navigation" page. Tap "Address" then the "Postcode" button. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Sun Jul 08, 2007 10:03 pm Post subject: |
thanks for replying i have 512 mb card, i click navigate to - address - postcode and before i could time a whole postcode ie ex1 1aa with the space now i cannot and its annoying.
the map i have is uk and ireland vers 675 |
DennisN Tired Old Man
Posted: Sun Jul 08, 2007 10:27 pm Post subject: |
Don't put a space in the postcode. _________________ Dennis
Two of them are obesiting!! |
Posted: Sun Jul 08, 2007 10:49 pm Post subject: |
have tried that still doesnt work |
Posted: Sun Jul 08, 2007 11:07 pm Post subject: |
If EX1 1AA is supposed to be genuine, it isn't a valid postcode!!
Try BA29ET (that's BA2 9ET without the space) and you should be able to tap on Lower Bristol Road. _________________ Dennis
Posted: Sun Jul 08, 2007 11:11 pm Post subject: |
nope doesnt work only recognises 3 or 4 digits |
Posted: Sun Jul 08, 2007 11:17 pm Post subject: |
When you downloaded your map, you should have also received a couple of files called Zip Codes, which are the postal code files for the map. You should have installed these as well as the map. _________________ Dennis
Posted: Sun Jul 08, 2007 11:20 pm Post subject: |
i only got the map file that was it, how would i get these files now? and why didnt i get them?
cheers |
Posted: Sun Jul 08, 2007 11:23 pm Post subject: |
They would have arrived with the map. Check the centre panel in TT Home, very bottom. _________________ Dennis
