fcat Regular Visitor
Posted: Fri Mar 09, 2007 7:11 pm Post subject: How do i add ALL european cameras ? |
I have downloaded the cameras database for Germany, spain, France, Portugal and a few other countries, each of the countries has about 10 different types of cameras but all the files are labelled the same for each contry, how do i put all of them on my tomtom go ?
cheers for any help |
Posted: Fri Mar 09, 2007 7:14 pm Post subject: |
ie there is a "speed 30" file for each country, wont the files overwite each other?
is there only a certain amount i can enable at one time on my tomtom ? |
Posted: Fri Mar 09, 2007 7:27 pm Post subject: |
You can put the POI files into seperate map folders (if you have seperate maps on the device) or if its a single Europe map they will all have to go into the one folder.
Version 5 software is limited to 39 Custom POI's while version 6 is limited to 100 Custom POI's.
If you want you can always combine the POI files - I would combine each speed camera file with the same speed, so it wouldn't matter which country you were in the single POI file would contain the data. Have a look at POIEdit which can be used to concatenate POI files - Mike |
Posted: Fri Mar 09, 2007 7:29 pm Post subject: |
Excellent thanks ever so much for the info!
will have a look at the link now
cheers |
Posted: Fri Mar 09, 2007 7:59 pm Post subject: |
ok just donloaded the POIedit, checked the FAQ and the forum but theres nothign explains how to combine the files, any help appreciated
cheers |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Fri Mar 09, 2007 8:30 pm Post subject: |
You Open the first POI File and then Append all subsequent Files you wish to merge.
These Commands are in the File Menu on the Menu Bar. ;) _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Fri Mar 09, 2007 8:33 pm Post subject: |
thanks will give it a go, although just relaised if i pay £2 to join here for a month theres the single files POI's for europe and for the UK!!! |
