JohnHall Occasional Visitor
Posted: Fri Oct 27, 2006 1:39 pm Post subject: Need to input probably 1000 POI's |
Dear All,
I am about to purchase a GPS system and would be grateful for guidance. I need to input between 1 and 2 thousand POI's (car garages) so that I can see which dealerships I am near as I drive around the Country. Which system would any of you recommend I purchase bearing in mind the number of POI's which may grow, and also ease of putting them in... This will not be a gradually increasing operation, it needs to be done as soon as I have the system. I have read "how to make a POI" which seems clear enough but highly laborious.
Thanks in advance.
John |
alix776 Pocket GPS Moderator
Posted: Fri Oct 27, 2006 1:44 pm Post subject: |
at the moment id go with tt6 as you can use 100 poi catagories also if you use make ov2 it will convert a .csv list of garages to .ov2 format with will then work as a poi in the tomtom application _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Fri Oct 27, 2006 5:05 pm Post subject: Thanks Alex... |
Should have put this in the original post... but is it possible to enter a POI by just putting in the full postcode or do they all have to have the co-ordinates fed in that will make the process very time consuming?
Thanks again. |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Oct 27, 2006 6:31 pm Post subject: |
If you settle for a TomTom, make a note of THIS site.
Search Car Dealers Generate POI's and save .asc file. Download the file coverter, drag and drop .asc file onto convertor icon which gives you .ov2 and .bmp files both of which you copy to your GB map. All you have to do then is Navigate to - POI - Car Dealers. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Fri Oct 27, 2006 7:26 pm Post subject: Re: Thanks Alex... |
JohnHall wrote: | Should have put this in the original post... but is it possible to enter a POI by just putting in the full postcode or do they all have to have the co-ordinates fed in that will make the process very time consuming? | You can Input Postcodes into AutoRoute and it will generate the Lat/Long in the Saved AXE File. The AXE File can then be converted by a Program like POIConverter to an OV2 File.
Don't rely on the accuracy of the Postcodes and be aware that Postcodes come and go.;)
Cross checking is time consuming. I know from experience. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
