Pocket GPS World :: View topic - Windscreen Mount - Nuvi 300
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
hotlips69
PostPosted: Sun Oct 01, 2006 11:26 pm    Post subject: Windscreen Mount - Nuvi 300 Reply with quote
There is a disc that I presume fits to the windscreen that has a red circle on one side and black plastic on the other.
There is no mention in the manual how to use it/if this is needed at all?
Which way round does it go as the mounting arm will secure itself to either side (by a magnet possibly?)
Could I not use it and just attach the mounting arm direct to the windscreen without it falling off?
PostPosted: Sun Oct 01, 2006 11:34 pm    Post subject: Reply with quote
If the Red sided disk is what I suspect DO NOT ATTACH IT TO YOUR WINDSCREEN, these are intended to be used for a dashboard mount, the red bit peels off and reveals a very strong adhesive (it doesn't come off very easily at all). - My advice unless you really need this put it back in the box.
The device should be supplied with a mount that will secure to the windscreen on its own, there should be a suction cup type device attached to the end of the mounting arm - this alone is sufficiant to attach and secure the device to the screen - Mike
hotlips69
PostPosted: Sun Oct 01, 2006 11:48 pm    Post subject: Reply with quote
Thanks very much for the quick reply.
People on this forum are so helpful! :D
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
22.094 (25 Sep 24)
