Pocket GPS World :: View topic - help help help tomtom one
waynedance
PostPosted: Fri Sep 08, 2006 10:23 pm    Post subject: help help help tomtom one Reply with quote
got the new tomtom one regional and messed it up.
added the camera database no problem, added a voice file and now it does not work, just sticking on the hand flash screen.
i have tried to format the card as well but does not let me (not write protected).
please help out a noob........
waynedance
PostPosted: Fri Sep 08, 2006 11:19 pm    Post subject: Reply with quote
i managed to get the card to format.
does not find device when i connect with the cable, just keeps coming up with the "do you want to connect to computer" screen.
click yes and the same screen comes up a while later
any help would be great.
i think i will leave the voices alone.
TonyHoyle
PostPosted: Fri Sep 08, 2006 11:21 pm    Post subject: Reply with quote
If your PC has a card slot (modern ones tend to) then put the SD card into that and copy your backup back onto it.
Tumbleweed
PostPosted: Fri Sep 08, 2006 11:27 pm    Post subject: Reply with quote
Why do people insist on formatting cards when its nearly always not necessary and more often than not going to screw something else up...wrong FAT format, delete needed files, etc?? No help to you but maybe this will stop someone else completely erasing their card before asking for help!
Do you have a card reader? If so, copy the backup you took prior to formatting your card, back onto it, so its the same as it was. If you dont have one, go and buy one tomorrow. Oh, and buy a bigger card, so you can keep the 'original' untouched (after you have copied the files back)..again a bit late for you, but maybe good advice for the next person, and if you get it working, you can leave that as your good copy 'in case of emergencies'.
Tw
waynedance
PostPosted: Fri Sep 08, 2006 11:45 pm    Post subject: Reply with quote
i tried to delete the files only but it would not have it.
all i could do was format, yes i do have a card reader on my laptop and have copied the back up across to the SD card.
all is fine now just cannot connect via the cable as said.
cheers.
oh new to or this sat nav stuff.
PostPosted: Sat Sep 09, 2006 7:33 am    Post subject: Reply with quote
Make sure the Plugs are pushed in fully. With a new Unit they may be rather tight.
TT Via 135 App 12.075: Europe Map v1135
Tumbleweed
PostPosted: Sat Sep 09, 2006 11:32 am    Post subject: Reply with quote
or try copying the files onto a bigger card, maybe the extra voice has used enough space that what is left isnt big enough? IIRC with less than 2MB free space, my 300 kept crashing.
Tw
trevor.dowle
PostPosted: Sat Sep 09, 2006 11:42 am    Post subject: Re: help help help tomtom one Reply with quote
Further to the other replies: Did you download and install the correct data.chk file?
The reason I ask, is that the wrong data.chk file will produce the symptons you have described.
Regards
Trev Dowle
TomTom 730 T
22.094 (25 Sep 24)
