Pocket GPS World :: View topic - Missing Moving Map
Missing Moving Map
laurie53
PostPosted: Mon Aug 21, 2006 3:50 pm    Post subject: Missing Moving Map Reply with quote
Apologies if this has come up before (I can't be the only one with this problem!) but I've spent an hour searching the froums and can't find anything.
I'm running a Globalsat BC337 in the CF slot of an Axim X51v, TTN v 5.210
When I fire up Tomtom it does not see any satellite signal, tho' I know it's there. When I put in a route nothing happens, until and unless I bring up a non TT screen e.g. I bring, say, Calendar to the foreground. I then get full and accurate voice instructions, tho' I can't see the map of course. If I then close Calendar, and bring TT to the foreground, the map shows a dead accurate position (with good satellite info), but does not update as I drive, nor do I get any more voice. I can repeat this process as often as I like - always good voice until I bring a TT screen up, then a totally accurate position but no update. Tomtom will only update if it is not the foreground screen!
Bizarre eh?
Any suggestions?
Laurie
PS As amatter of interest, Dell GPS and Co-pilot work perfectly - no, don't ask why I want Tomtom when I've got two working systems!
PostPosted: Mon Aug 21, 2006 5:56 pm    Post subject: Reply with quote
Laurie, I think the general view is that this will not work with the x51v CF GPS and TT (Welll not without major problems along the way) please have a read through the three pages HERE which detail this problem in quite some depth it might give a few more ideas, most users gave up and resorted to a BlueTooth unit from what I can remember.
Welcome to the forum by the way - Mike
laurie53
PostPosted: Tue Aug 22, 2006 9:54 am    Post subject: Reply with quote
Thanks for the response, Mike. It seems that this combination will not work.
I knew that Tomtom had compatibility problems with CF receivers, but understood, from their own website, that the latest version had addressed these
Laurie
laurie53
PostPosted: Sun Aug 27, 2006 6:32 am    Post subject: Reply with quote
Just a final update and confirmation. I have now set up with a Bluetooth receiver and system runs perfectly.
Thanks for the help
Laurie
linknet
PostPosted: Sun Aug 27, 2006 9:54 am    Post subject: Reply with quote
Thanks for the help
Laurie
I have an Axim X51v and I can't get TTN 5.21 to run in landscape mode properly. Everything is incredibly slow, the menus redraw like treacle across the screen and the map view takes ages to refresh. Have you tried yours in landscape ? Has anyone else any ideas ?
Regards
Roger
PostPosted: Sun Aug 27, 2006 11:15 am    Post subject: Reply with quote
Do you use POI's Enabled, or only Warn When Near?
Using the Enable POI Function on a PDA will slow down the Screen updating.
TT Via 135 App 12.075: Europe Map v1135
linknet
PostPosted: Sun Aug 27, 2006 11:34 am    Post subject: Reply with quote
I always disable all POI's and was not using Warn When Near. This is something much more fundamental and related to landscape mode. You can actually watch the menu screens slowly redraw across the screen.
I've also tried modifying the executable and removing the VGA-Aware resource. This runs fast enough in QVGA landscape but it will not load properly from landscape mode on the PDA. You have to switch the PDA to portrait mode then run TTN5.21 from there in landscape mode. Also there is then a redraw bug in the map view - when you move the map to another location it doesn't always redraw.
Regards
Roger
laurie53
PostPosted: Tue Aug 29, 2006 9:44 am    Post subject: Reply with quote
Linknet
Tried it in landscape mode (and upside down!) and had no problems at all
Laurie
linknet
PostPosted: Tue Aug 29, 2006 9:58 am    Post subject: Reply with quote
laurie53 wrote:
Linknet
Laurie
That's very odd. Was it definitely running in VGA mode ?
Regards
Roger
laurie53
PostPosted: Mon Sep 04, 2006 11:13 pm    Post subject: Reply with quote
Sorry, don't know; I just switch the thing on! Laughing Out Loud
Laurie
laurie53
PostPosted: Wed Oct 25, 2006 10:52 am    Post subject: Reply with quote
Just another update for info. TomTom 6, the latest version, works perfectly (and very fast) with my X51V and a CF receiver (Globalsat BC337)
Laurie
22.094 (25 Sep 24)
