Pocket GPS World :: View topic - No fix problems
No fix problems
Steve_T5
PostPosted: Wed Jun 21, 2006 10:51 am    Post subject: No fix problems Reply with quote
Hi, I'm hoping someone here can shed some light on a problem i have with my pda/gps setup.
I have an iPAQ hx2110, TomTom Navigator 5.0 and a GlobalSat BC-307 CF receiver. When i launch the tomtom software it takes an age to get a fix, even with the external antenna connected. Once it has a fix it will lose it again at irregular intervals, sometimes within seconds, other times within a few minutes. It then takes up to two minutes to get another fix.
Tomtom is configured as Other Cable NMEA GPS, set at 4800 baud and connected to CF_CARD GE.
I tried soft reseting the device after plugging in the card, then starting tomtom, and i tried starting tomtom and then plugging in the card and it's still the same.
I ran Winfast Navigator and TTFF on a cold start is 50 seconds average, with TTFF on a warm start at 6 seconds average. Once it has a fix in the winfast software, it will stay there all day, varying between 3 and 8 sats.
To me, this rules out a fault with the card, and points to something in the tomtom setup that is causing the problem.
Any suggestions would be greatly appreciated.
Regards
Steve
alix776
PostPosted: Wed Jun 21, 2006 11:03 am    Post subject: Reply with quote
are you using an sd card for the maps on the 2210 a change to a faster sd card might help also i seem to remember a sd card update on the hp website for the 2210
device Lumia 950 xl
Steve_T5
PostPosted: Wed Jun 21, 2006 11:12 am    Post subject: Reply with quote
I do use an SD card for the maps. My card is a 1GB Kingston Technology. As far as i know, Kingston are one of the better makes.
alix776
PostPosted: Wed Jun 21, 2006 11:16 am    Post subject: Reply with quote
what receiver are you using i used to have a pretec cf and it could be terrible at geting a fix with out and external antena
one did have to do was make sure i gt a fix while the truck was stood still
device Lumia 950 xl
Steve_T5
PostPosted: Wed Jun 21, 2006 11:23 am    Post subject: Reply with quote
As listed in the first post, the reciever is a GlobalSat BC-307 with SiRF-II chipset. It doesn't have any problem getting a fix in the Leadtek Navigator program, only when using tomtom...TTFF is not so much the issue...it's more the fact that it won't maintain fix when it's got one in tomtom.
alix776
PostPosted: Wed Jun 21, 2006 11:35 am    Post subject: Reply with quote
ok it its sirf 2 then it could be where your putting the 2210 in the car if its intimiant then it could be that your getting a low signal.
if you move the ipaq out of the car does it get a fix
device Lumia 950 xl
Steve_T5
PostPosted: Wed Jun 21, 2006 12:02 pm    Post subject: Reply with quote
The iPAQ is an hx 2110 Smile
Have tried it inside and outside the car. The config screen shows as many as 6 grey bars, it just never gets a lock. I'm convinced its an issue with the tomtom software as a lock is obtained use gpsinfo2003.exe, and also using leadtek navigator...which also gives me a fix in the house! , even if it is a weak one.
alix776
PostPosted: Wed Jun 21, 2006 12:06 pm    Post subject: Reply with quote
what version of tomtom are you using and what settings are you using
device Lumia 950 xl
Steve_T5
PostPosted: Wed Jun 21, 2006 12:07 pm    Post subject: Reply with quote
alix776
PostPosted: Wed Jun 21, 2006 12:20 pm    Post subject: Reply with quote
try going to 5.21 or the lastest version this should help things
device Lumia 950 xl
22.094 (25 Sep 24)
