schneid Regular Visitor
Posted: Tue Dec 20, 2005 4:14 pm Post subject: Windows TomTom Menu Builder |
Found this over in the Go forum:
http://www.gregoryduncan.com/ttmd/index.htm
Free downloadable program to modify TomTom menu pages on your desktop. |
mandlebrot Occasional Visitor
Posted: Sat Mar 25, 2006 2:59 am Post subject: |
Thanks for the heads up |
lupos0_1 Lifetime Member
Posted: Sat Mar 25, 2006 10:52 am Post subject: |
I have been using this program for a while now and it is definitely one of the easier ones to use _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
Robin2 Lifetime Member
Posted: Sat Mar 25, 2006 11:52 am Post subject: |
Does it allow Rotate Scren by 90 degrees? The last menu builder I tried about 9 months ago would not do this
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
Posted: Sat Mar 25, 2006 12:41 pm Post subject: |
You can build your menus in either 3x2 or 2x3 so I suppose you could get round it that way.
Other than that, I believe that this is a option in the preferences section. _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
Posted: Sat Mar 25, 2006 2:52 pm Post subject: |
Yes, it was an option in the other menu builder program I tried, but it didn't work!!
Satmap Active 10
Posted: Sat Mar 25, 2006 2:56 pm Post subject: |
I see. That option definitely works on this 1. _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
Posted: Sat Mar 25, 2006 2:58 pm Post subject: |
Fine, I'll try it then. On the other software it would rotate by 180 degrees, but not 90
Satmap Active 10
Posted: Sat Mar 25, 2006 3:06 pm Post subject: |
I see what you mean now about the 180 degrees
It seems to be the same in this one too.
The only way around it would be to go into change preferences and then on page 6 is the rotate screen function.
I suppose that sort of defeats the object though doesnt it?? _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
julianbarker Lifetime Member
Posted: Sat Mar 25, 2006 6:50 pm Post subject: |
I just used the default menus to set up TT as I liked, then installed the customised menu. The fact that I can't rotate without removing the custom menu has never bene a problem as I have never had to do it.
If I did I would just ad a character to the end of the custom menu file in explorer and then remove the chaacter to restore the custom menus. It is not rocket science. |
Yes, that was the point where I gave up last time!
Satmap Active 10
houghw Occasional Visitor
Joined: Mar 02, 2006 Posts: 31 Location: Cambridge, England
Posted: Wed Jan 02, 2008 5:08 pm Post subject: |
I appreciate that this is quite an old thread but I thought I'd add a comment/question...
I too downloaded this software and used it to create a custom menu for my Go 500. I found it very easy to use and the custome menu worked great for my needs.
Unfortunately I then updated my software to version 7 and purchased a new UK map to take advantage of the 'map-share' functionality of the version 7 software.
My problem is that now, once I have flagged a location on the map to correct, I have to manually disable my custom menu (rename TomTom.mnu to TomTom.mnu.old) so that I can use the default menu to access the map correction sub-menu.
I have looked at the software site a couple of times to see if the software has been updated to include the map-share functionality but alas it does not look like this had happened yet or whether it is likely too any time soon
Can anyone out there tell me if there is any alternative software that will allow me to add the map-share functionality to my custome website or is it possible to lift the icons off of the default menu some how?
Thanks for you r time.
Wayne |
Posted: Wed Jan 02, 2008 5:50 pm Post subject: |
Wayne, this is not possible when running version 7 software, you can use a custom menu, but only at the cost of MapShare and HelpMe, there is no way (as yet) to add this functionality to a custom menu.
No Custom Menu = MapShare available
Custom Menu = No MapShare availability
- Mike |
