topref Pocket GPS Verifier
Joined: Sep 08, 2005 Posts: 347 Location: Carmarthenshire
Posted: Mon Mar 06, 2006 11:05 pm Post subject: HP iPAQ 2210 battery useage |
Can someone help here please? I bought my 2210 about six or so months ago and it eats battery power even when left off. After about 5 or so days, battery is completely drained and I then have to go through all the set-up procedure again, down to installing user name etc. I purchased a replacement battery and this also discharges at the same rate.
I am in a type of occupation where I use the car one day to go somewhere and I work there for at least a week so I rarely use the PDA daily. My main (only) use of it is to use Tom Tom for navigation.
Is this normal for this model PDA? If not, what are my options?
Further to this I upgraded from TT5 to TT5.21 and I checked the version to confirm the upgrade was accepted. But, after this complete discharge, it reverts to the TT5 version.
Thanks in advance for any responses. |
lbendlin Pocket GPS Staff
Posted: Mon Mar 06, 2006 11:12 pm Post subject: |
yes, this kind of power consumption is common for the older Windows PDAs. When you "switch them off" they merely go to a standby mode but keep consuming energy.
An chance to use a car charger? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Mar 06, 2006 11:28 pm Post subject: |
Thanks for a very fast response. I do use a charger while travelling but as I said, I'm often not in the car for sometimes weeks at a time.
Can you recommend a PDA which would be compatible with my Fortuna clip-on GPS receiver and which would retain it's charge?
Also, is it normal for an upgraded v5.21 to revert to version 5 or am I doing something wrong when upgrading? I assume that the upgrade is to the PDA as opposed to the card. Am I correct in thinking this?
Thanks again |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Mon Mar 06, 2006 11:38 pm Post subject: |
I have several suggestions that may help a little..Firstly get Sprite Backup so if your battery goes flat you can restore it to its former state.Second get WisBar Advance .. With this prog you can make sure all your application have shut down and are not running in the background eating up your battery..Now the third one I have not tried but i have been told that by removing the storage card helps to preserve the battery,perhaps someone else may have thought on this.
Dave _________________ TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest |
Posted: Mon Mar 06, 2006 11:44 pm Post subject: |
oddsock wrote: | I have several suggestions that may help a little..Firstly get Sprite Backup so if your battery goes flat you can restore it to its former state.Second get WisBar Advance .. With this prog you can make sure all your application have shut down and are not running in the background eating up your battery..Now the third one I have not tried but i have been told that by removing the storage card helps to preserve the battery,perhaps someone else may have thought on this.
Dave |
Sorry I should have made that clearer and said " you can restore the ipaq to its former state".
Garmin Quest |
Posted: Mon Mar 06, 2006 11:51 pm Post subject: |
Thanks for that. The problem I would still have though is that the PDA would be useless to me on my onward journey because my sprite back-up would be on my PC at home. I should have added that I frequently travel to one place for a week then on to somewhere else before going home.
Next week I am overseas for about 15 days with no way of keeping the PDA charged.
I've just googled wisbar advance and will take a look at it. |
Posted: Mon Mar 06, 2006 11:58 pm Post subject: |
You take the backup file with you saved as an exe file on your storage card .If your battery goes flat and you lose your data pop in your spare charged battery ..tap the exe file and your pda will be restored
Garmin Quest |
Posted: Tue Mar 07, 2006 1:50 am Post subject: |
OK. thanks for the response again.
Also is there someone here who can answer my specific questions posted earlier:
1. Is the upgrade from v5 to v5.21 saved to the PDA or should it be saved to the card? If the latter, what am I doing wrong in that I am losing the upgraded version every time I lose the PDA's power?
2. Is there a better PDA on the market that holds its charge better than the 2210?
Thanks |
monkeyking Occasional Visitor
Posted: Tue Mar 07, 2006 1:39 pm Post subject: |
Hi there, I've just joined and this is my first post (in case you don't recognise the nickname)
Topref, i had the same issues on my 2190 (TTN v5.21) regarding battery drain and i found the answer on other forums so i won't take the credit for this solution:
"If your unit is having problems turning on, you may want to go to Start, Settings, Today and click on the tab that says Items. You will see an option at the bottom that says "Today Timeout". If you take the checkmark out of this box, it should stop the issue from happening. You should not lose any of your information from the soft reset, or from this work around."
run hp protecttools
uncheck lock device (without stopping programs and encrypting data
check log off (stop running programs and encrypt data) after: 1min.
follow encryption process...
As for Navigator 5, when my battery drained itself and i recharged it was always 5.21. This is strange that you revert to an earlier version. Maybe you have the application stored on your SD card and it reads and loads from there. As far as i know, when you update your app, it is to the internal memory but if you have the original TT SD card, it will also have the app on there so it could be loading from the card.
I think the battery drain will stop now because mine has following those instructions and i haven't charged it yet for 2 days.Update TTN5 and it should stay there....Good Luck! |
Posted: Tue Mar 07, 2006 2:14 pm Post subject: |
to the forums..As I am following this topic and still learning could you tell me if you are running the new 2005 operating system as I cannot find the option of the settiings you describe on my 2210 running windows 2003??
Garmin Quest |
Darren Frequent Visitor
Posted: Tue Mar 07, 2006 2:38 pm Post subject: |
oddsock wrote: | to the forums..As I am following this topic and still learning could you tell me if you are running the new 2005 operating system as I cannot find the option of the settiings you describe on my 2210 running windows 2003??
Dave |
Those settings are for WM5.0. They do not apply to the 2210. You say you cannot re-charge for a number of days? Will you really have no access to power at all? If so then perhaps a battery pack would solve your issues? You can buy an external pack that takes AA batteries which you use to top up the charge on your PDA. _________________ Darren Griffin |
Posted: Tue Mar 07, 2006 6:15 pm Post subject: |
Thanks for all the input
Darren, I refer to my last posting and the questions posed there. I know you are one of the top guys here at pocketgpsworld and have seen your helpful posts at alt.rec.gps. What are your answers to my two questions? Should I lose the upgrade just because the power drains from my PDA? Surely, it's the software on the card that's upgraded. Also if you were to opt for a replacement PDA, what would be your choice?
I do have access to power but one of these days I'm going to forget to put the PDA away and it'll be nicked from my hotel room.
Thanks |
Posted: Tue Mar 07, 2006 6:34 pm Post subject: |
topref wrote: | Also is there someone here who can answer my specific questions posted earlier:
1. Is the upgrade from v5 to v5.21 saved to the PDA or should it be saved to the card? If the latter, what am I doing wrong in that I am losing the upgraded version every time I lose the PDA's power? |
Although the install is on the card, it installs to main memory. The update updates this installation so when power expires the installation is wiped. Re-installing from the card effectively replaces it with the version on the card. To avoid this you need to replace the installers on the card (normally in Autorun) with their updated versions.
Quote: | 2. Is there a better PDA on the market that holds its charge better than the 2210 |
The newwer WM5.0 PDAs use persistent storage so do not wipe their memory when power fails. If it loses power all that is needed is a re-charge and it will be as it was before. _________________ Darren Griffin |
Posted: Tue Mar 07, 2006 8:57 pm Post subject: |
Thanks Darren. |
Posted: Wed Mar 08, 2006 11:33 am Post subject: |
Darren wrote: | oddsock wrote: | to the forums..As I am following this topic and still learning could you tell me if you are running the new 2005 operating system as I cannot find the option of the settiings you describe on my 2210 running windows 2003??
Dave |
Those settings are for WM5.0. They do not apply to the 2210. You say you cannot re-charge for a number of days? Will you really have no access to power at all? If so then perhaps a battery pack would solve your issues? You can buy an external pack that takes AA batteries which you use to top up the charge on your PDA. |
...Ooops! Sorry about that, am new to the PDA world! Maybe there should be a "my first pda" available, hmmmm...i spot a niche in the market!!! _________________ "I want to hug you...and kiss you...and call you George!" |
