Pocket GPS World :: View topic - tomtom 300
tomtom 300
davidwynn
PostPosted: Wed Mar 01, 2006 11:26 pm    Post subject: tomtom 300 Reply with quote
hi have loaded speed camera software to my tomtom 300 but can not see
cameras on screen and it will not alert me when i go by one if i go into the tomtom i can see all the files there but just will not work with them
PostPosted: Thu Mar 02, 2006 7:45 am    Post subject: Reply with quote
You will need to set up the Camera Warnings by going into Change Preferences and Manage POI. Then select Warn When Near. Follow through the various menus.
This will set up the Visual and Audible Display of Cameras.
TT Via 135 App 12.075: Europe Map v1135
davidwynn
PostPosted: Thu Mar 02, 2006 8:17 pm    Post subject: Reply with quote
tryed to do that but still not woking
PostPosted: Thu Mar 02, 2006 8:32 pm    Post subject: Reply with quote
When you say
do you mean that you can see them when you look at the contents of the card when it is connected to the PC or that you can see them on the Go's own screen in "Manage POIs"?
PostPosted: Thu Mar 02, 2006 8:33 pm    Post subject: Reply with quote
Have you got the volume turned down?
davidwynn
PostPosted: Thu Mar 02, 2006 8:52 pm    Post subject: Reply with quote
all the files aer on the tomtom bet when i go by speed camera it can not show me there is one
PostPosted: Thu Mar 02, 2006 8:58 pm    Post subject: Reply with quote
Can you see them on the Go's own screen in "Manage POIs"?
davidwynn
PostPosted: Thu Mar 02, 2006 9:54 pm    Post subject: Reply with quote
yes i can see them
PostPosted: Thu Mar 02, 2006 10:02 pm    Post subject: Reply with quote
Then as Richard mentioned earlier you need to configure them - this will have to be repeated for each one you have loaded (speed zoned set-up needs 23 POI's to be set - write them all down and tick them off as you go) - one other thought have you selected Hide POI by any chance, it should have a red X accross the icon on the first page of preferences - if not this could be your problem - Mike
davidwynn
PostPosted: Thu Mar 02, 2006 11:36 pm    Post subject: Reply with quote
looking on the tomtom screen in enable pol it has got pocket gpscameras
i have put tick to that one is there some were else to put a tick
davidwynn
PostPosted: Thu Mar 02, 2006 11:43 pm    Post subject: Reply with quote
hi you say there are 23 to be set up i only have one it says pocket gps cameras and all you can do is put a red tick in the box by it
PostPosted: Fri Mar 03, 2006 12:24 am    Post subject: Reply with quote
David if you only have the one to setup then that is fine - you will have downloaded the single database that contains all the cameras, the 23 I refered to is for the speed zoned set-up so we can disregard this for now.
When you go into the warn when near POI first screen sets a distance circa 273 yards?
on the next screen you select a warning noise bell 1 etc (unless you have something else loaded, use the test button to find the audio prompt you like the most)
On the last screen there is a check box for "Warn when near POI" have you selected this - if so you need to plan a route to be warned of a camera, driving around without a route planned will not give you a warning.
The benefit of the Warn when POI on route being checked is that it will reduce the amount of warnings on adjecent roads etc. to the detriment of driving without a route - no route = no warnings when this is checked, is this what is wrong per chance??
Mike
PostPosted: Fri Mar 03, 2006 1:16 pm    Post subject: Reply with quote
Please David, if you could use the occasional capital letter, full stop and question mark, it would be easier to work out whether you are telling us something or asking a question.
Some of us are not natural 'txtspk' readers Smile.
davidwynn
PostPosted: Sat Mar 04, 2006 1:05 am    Post subject: Reply with quote
I have followed Mike's instructions, but it still appears not to be working.
One question does it show the location of speed cameras when you look at a map on the screen or does it only show the speed cameras when you plan a route?
Also when I go into Add POI, on that screen I have Pocket GPS Cameras, Restuarants, Hotels and Motels, Petrol Stations and Places of Worship. If I press on any of these bar speed cameras it gives me a list of all different locations for these POIs, but if I press on Pocket GPS Cameras, all it says is no POI found. Is this correct?
Many apologies for the bad grammar, now got my own secretary.
PostPosted: Sat Mar 04, 2006 1:37 am    Post subject: Reply with quote
From what you describe you have loaded too many POI's - the limit is 39 custom POI over and above the supplied ones so you will need to delete some to be able to to use the Speed Camera database if this has been loaded after the others -
first in last out approach applies here, have a serious look at what you actually need - and delete the rest, as for if the device will show the cameras on the map with or without a route (your original question - my last answer - there is some logic somewhere) make sure you understand what happens when you select "Warn if POI on Route" is checked, if checked you need the route programed to display the warning, if not it will warn you when you get close to the POI, in addition if the camera POI are disabled in the enable / disable option then they wont show on the map at all, other than for warnings when configured, but you can only have 39 custom - Mike
22.094 (25 Sep 24)
