bullmastiff Occasional Visitor
Posted: Mon Feb 13, 2006 11:30 pm Post subject: tom tom one |
i'm sorry if this is not the correct place to ask this question i had touble navigating the forum
i have recently purchased a tom tom one and was wondering if it was possible to download speed cameras onto it
i am not technically minded so please keep the answers as clear as possible ..an idiots guide would be good
many thanks
debbie |
Oldboy Pocket GPS Moderator
Posted: Tue Feb 14, 2006 7:56 am Post subject: |
Hi Debbie, welcome onboard.
I've moved your Post to a more suitable place.
In answer to your question, yes, you can use the Speed Camera Download on the ONE.
There are several Threads that go through the process, but perhaps you might like to start with http://www.tomtomsatnav.info/pgps.html
Also have a read of this thread. Take it slow and it will all fall into place.
However, the first, and most important, thing to do is to make a Full Backup of the SD Card to your PC, before you make any changes to your Setup.
If you're still stuck, just Post Reply to this thread and someone will be along to help. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Tue Feb 14, 2006 12:57 pm Post subject: |
thank you so much for your reply ..and i'm sorry i placed the post in the wrong section
i have read the posts that you directed me too ...and i have two questions if i may
which set of cameras would you advise to download
(i have bought the tom tom one .to use as an aid to get me to dog shows that are held all over the uk :D ..hopefully i will get there on time now 8O )
and also can you direct me to where i download the files from ..
i said i would need an idiots guide 8O
many thanks for your help
debbie |
Posted: Tue Feb 14, 2006 8:19 pm Post subject: |
bullmastiff wrote: | i'm sorry i placed the post in the wrong section | No problem. You're not the first, and you'll not be the last.
bullmastiff wrote: | which set of cameras would you advise to download |
Personally I use the Speed Zoned Gatso (8 files), Speed Zoned Mobile (7 files), the Single Temp, Redlight and Specs Files.
bullmastiff wrote: | and also can you direct me to where i download the files from .. |
The Download can be found on the left of the Web Page, under GPS Central, and is http://www.pocketgpsworld.com/uksafetycameras.php
There is a 'Download the Database' Icon part way down the page.
Don't forget the Full Backup of the SD Card. You may have to take any unused Voices off the SD Card. Hint: Use the Change Voice menu in Change Preferences to do this. This will give you a bit more free memory on the Card, which is at a premium on a ONE. _________________ Richard
Posted: Wed Feb 15, 2006 3:39 am Post subject: |
thank you so much you are an angel :D
i'll be back if i get any problems ...so don't breathe too easy just yet
kind regards
debbie |
