Pocket GPS World :: View topic - XDAII BT 308 problem
brianleach
PostPosted: Sun Jan 08, 2006 5:15 pm    Post subject: XDAII BT 308 problem Reply with quote
fter an unexpected hard reset I am having difficulty getting info to pass from my bluetooth GPS unit to my XDA II.
It worked before the crash and has been restored from a fairly recent backup but I cannot get it to work.
I have removed everything relating to the program even registry entries and reinstalled.
I can pair the unit and using Bluetooth tools it tells me that the I should use Com Port 7 (which I recall is the one I used before) but a port scan seems to think port 4 is the one.
In addition the Baud Rate should be 38400 but the default comes up with 4840.
Has anyone any ideas please?
Brian Leach
alix776
PostPosted: Sun Jan 08, 2006 8:10 pm    Post subject: Reply with quote
sue other blue tooth receiver and then select com 7 also make sure all incoming beams is unchecked in the connections tab ignore the com 4 port scan
device Lumia 950 xl
brianleach
PostPosted: Mon Jan 09, 2006 9:14 am    Post subject: XDAII BT308 problem Reply with quote
Thank you for the response.
I have unchecked the beam box bi=ut still no luck.
Could you supply more details on the other bluetooth reciver issue.
Brian Leach
22.094 (25 Sep 24)
