Kwakers Lifetime Member
Posted: Sun Oct 19, 2008 11:32 am Post subject: SD card on Nuvi 660 |
If I load a card in my nuvi it will only play music files anything else is invisible. any suggestions ?
also I have some poi's that cannot be removed ( even garmin tried ) If i formatted the drive would I have to buy the maps ?
Bob |
Posted: Sun Oct 19, 2008 2:07 pm Post subject: |
Quote: | If I load a card in my nuvi it will only play music files anything else is invisible. any suggestions ? |
What else is one the card you want to see?
Quote: | also I have some poi's that cannot be removed ( even garmin tried ) If i formatted the drive would I have to buy the maps ? |
Custom POIs you've added? Search for any files that end with the extension gpi (such as poi.gpi) and move them to your PC (don't delete them). Usually POIs are in a folder called Garmin/poi on the unit or the SD Card.
Don't format the Nuvi drive. |
Posted: Mon Oct 20, 2008 10:05 am Post subject: |
I downloaded the free Roadtour finest 500 , on checking the properties it shows as a application so I presume in needs to be installed directly to the unit ?
Any thoughts on formatting ?
Thanks, Bob |
Posted: Mon Oct 20, 2008 10:36 am Post subject: |
Quote: | I downloaded the free Roadtour finest 500 , on checking the properties it shows as a application so I presume in needs to be installed directly to the unit ? |
No. You plug your Nuvi into your PC and run the app on your PC. It'll install the RoadTour to the unit or the card depending on what you choose.
Quote: | Any thoughts on formatting ? |
Sorry i don't use SD Cards so i don't know. |
Posted: Mon Nov 17, 2008 11:33 am Post subject: SD Card |
Hi Paul,
sorry for long delay in replying , daughter pinched sat nav just got it back.
Have installed as you said so should be ok now .
many thanks.
Bob |
